http://www.mercuryracing.com/propellers/bravoifs.php
Bravo I® FS Outboard
Overview
The Mercury Racing® Pro Finish Bravo I FS outboard propeller offers excellent time-to-plane performance, sweet mid-range punch, and awesome top-end speeds for bass, flats, cat flats, and performance center-console bay boats. The stainless steel prop, designed for use on 150 hp to 350 hp four strokes including Mercury Verado,® Mercury Pro FourStroke, and competitor-brand engines, features four robust blades and a tuned exhaust tube. The shortened exhaust tube provides greater top-end speed, while minimizing stern lift for improved boat handling and performance.
SPECIFICATIONS
Pitch 22”, 23”, 24”, 25”, 26”, 27”, 28”, 29”, 30”, 31”
Rotation RH,LH
Finish Pro Finish
Mercury Propeller Bravo FS
Re: Mercury Propeller Bravo FS
Zum vergleich:
Bravo I® Verado & Sterndrive
Overview
Mercury Racing propeller specialists have enhanced the performance of the four-blade Bravo I propeller to strategic Lab Finishing specifications for maximum performance. Lab Finishing Technicians lab finish these popular Bravo One, X, XR and Sport Master sterndrive and Verado propellers by thinning propeller blade surfaces in specific areas, modifying the leading and trailing edges and balancing the propeller all for maximum efficiency. The propellers provide top performance in a variety of performance boat applications.
The Mercury Racing Lab Finished Bravo I propeller offers great planing performance, excellent mid-range speeds and awesome top end speeds, The Bravo I propellers are designed for Cats and step bottom and center console boats looking for the ultimate top end speeds and are available in LH and RH rotations with one-inch incremental pitch sizes, ranging from 22" to 36".
SPECIFICATIONS
Diameter 15 1/4"
Pitch 22" - 36"
Rotation LH & RH
Finish Lab
Applications
Designed to run 60+ MPH with medium bow lift
For 300 - 600 HP sterndrive vee, stepped bottom vee & air entrapment hulls
Overview
SPECIFICATIONS
Diameter 15 1/4"
Pitch 22" - 36"
Rotation LH & RH
Finish Lab
Applications
Hier noch mal was zu dem abgedrehten Auspuffrohr.
2017 Neue Props.
