http://www.hardin-marine.com/detail~ID~2335.aspx
Have you used this item?
Be the first to Write a Review
Hardin Marine Sea Pump Overhaul Kit
625-4178
$169.99
Order Options:
Qty:
Add To Cart
Add To Saved Cart
Cooling Systems, Sea Pump Rebuilds
Stainless Steel "Lifetime" Sea Pump Overhaul Kit
Finally a Sea Water Pump repair kit designed to do the job once and for all and will last a lifetime. Hardin Marine has designed an all new 316L stainless steel water pump impeller housing to replace the cheap factory plastic style housings used on original equipment applications. These impeller housings won't corrode, erode, or crack and fall apart like original equipment units.
The one piece rear impeller housing features a unique rear housing that has 1" NPT female inlet/outlet ports so that a wide range of fitting and hose connections can be used for ease of installation.
If your looking to do this job once and for all this could possible be the last sea water pump repair kit you ever buy look no further as this is the finest direct replacement sea pump repair kit on the market today.
The kit includes:
* O-rings
* Impeller
* Stainless Wear Plate
* Polished Stainless Steel Sea Pump Body
* Bolts, Nuts & Washers
Seewasserpumpengehäuse aus VA
