These new billet trim tabs are available for electronic or mechanical trim indication. Livorsi's billet trim tabs stretch across the boating spectrum; models are available for performance boats, center consoles, cruisers, workboats, run-abouts and military boats from 20 to 50 feet.
Tabs are constructed from CNC machined billet aluminum with a Mil-Spec hard coat anodized finish, hinge pins that are stainless steel and with the use of 5 anodes, these tabs are designed for complete saltwater protection for years of reliable service with a beautiful finish.
The electronic sender models are capable of reading trim indication with compatible NMEA 2000® compliant systems and Mercury VesselView®. The electronic IP68 sensor used on these tabs directly plugs into Livorsi's LED Position Indicators for immediate indication.
Hydraulic cylinders are designed with dual seals and 1500 PSI working pressure. Bolt patterns include Mercury and a smaller Livorsi bolt pattern for center consoles. Transom angles on these tabs may be adjusted without the need for special tools making these tabs easy to install and modify for your application.
Come see our new interactive Trim Tab and LED Indicator display, Booth G90
Livorsi Trim Tabs
Livorsi Trim Tabs
